Part Number: BQ40Z50
When I connect to the BQ40Z50 in my application, I can see a register named "Sustained Turbo Current" located at address 0x5F. But there is no mention of this register in the technical reference manual. Is there per chance an updated TRM?
There seems to be quite a few registers that arend outlined in the TRM that BQStudio sees.
Can I trust the output of registers that arent defined in the TRM? ie, if I read "Sustained Turbo Current" at register 0x5F can I expect consistent behavior?
Nate
