I have tried changing the BCII ref2 register.
Current sequence.
//disable automatic ac charge before changing any BCI registers
Write 0x30 to reg BOOT_BCI
//write to key to enable write to charge current set register
Write 0xe7 to reg BCIMFKEY
//write to charge current set low byte register since that is the only one I want to change
Write 0x32 to reg BCIIREF2
//Enable the automatic ac charge
Write 0x35 to reg BOOT_BCI
**at this point when I read back BCIIREF2, the current set point reg it reads 0x32 as programmed.
//plug in AC charger and now BCIIREF2 read 0x68
Following this sequence to no avail, does there exist a explicit sequence?
_Chris
