Part Number: TPS62082
Other Parts Discussed in Thread: TPS62843, TPS62825, TPS628301, TPS62840
Good morning,
I have a question regarding the TPS62082 Snooze Mode operation.
According to the datasheet, Snooze Mode is intended to improve efficiency at very low load currents, typically below 2 mA, by reducing the device quiescent current and allowing the converter to periodically wake up only when the output voltage drops by approximately 3.5%.
Could you please clarify what happens when Snooze Mode is enabled while the load current is consistently above 2 mA?
Thank you for your support.
Alessandro Cortese
