Other Parts Discussed in Thread: LM5118
Is there a way to freeze the chip and topology and at least manually change the value of one part and run the simulation? Web Bench assumes you want to design a fixed output Voltage with a variable input Voltage range. I want to simulate a design that has a fixed input Voltage and by changing the feedback resistor that goes to ground, change the output Voltage. For the load, I would like to put in a resistor rather than calling out a current. The next think I would like to do is replace that Voltage divider resistor going to ground with a programable current sink to set the output Voltage.
