Resistor divider with LM337
Other Parts Discussed in Thread: LM337
Good Day!
I need to get out of the voltage -1.25В with the Negative Linear Regulator LM337. When calculating a resistor divider, the resistor R2 = 0 Ohm. In this case, the pin ADJ is connected to GND? And do I need a resistor R1 = 120 Ohm?
