power path transistor, single FET, diod
Other Parts Discussed in Thread: BQ24172, BQ24170
For the bq24170/bq24172, there is differents appilcation circuit, which use 2 FET (power path transistor), single FET or Diod .
What are the conditions to use 2FET, single FET or Diod ?
Do you have application note which explain the better choice ?
Futhermore, what are the reasons to use or not a Zener diod between REGN and SW pin ? This diod is indicate optional.
Thanks and Best Regards,
Stéphane
