I want learn about uc3906 dual charger, Re resistor value calculation or its value at Fig.4 in datasheet.
Thank you very much
Basically this circuit does what the text above it says--it regulates the holding current for the two step current algorithm. I would encourage you to read the app notes on the product page about this IC to learn it.
There is also the newer bq24450.
Thank you for answer.
BQ24450 datasheet very clear and sufficient. I have solve my problem.
New question: bq24450 and uc3906 schematic is same, what differences as new features of BQ24450?
There are several existing posts on this topic, already on the forum. You just need to use the google search to find them. One such post is this design note: http://e2e.ti.com/support/power_management/battery_management/w/design_notes/1813.uc3906-vs-bq24450.aspx
