Is it accurate to say that TI assumes that the Open Circuit Voltage (OCV) characteristics of a cell does not change with cycle age nor with temperature? In other words, the SOC to OCV dependency is constant. Thanks, E
OCV will change with temperature. We have temperature information build-in as part of the chemistry data. As battery ages, the resistance will change, the z-track devices keep track of that.
Is it accurate to say the following: During an extended rest periods, the BQ20z65-R1 will determine the cell/pack SOC solely on the SOC vs OCV(T) curves?
That is not correct. There are other factors involved in calculating SOC. For instance, in relaxation doesn't mean the current is 0mA, and so impedance will be taken into consideration.
