TPS54260 Design Equations
Other Parts Discussed in Thread: TPS54260
I'm going through some of the design equations for a new design using the TPS54260 buck converter. In equation 12 and 13 on page 21 it uses a Rhs variable. But the variable is not defined with the rest of the variables. What does this variable correspond to?
A second question I had was regarding the SwitcherPro software. I've gone through the design of my potential supply for the TPS54260 only to find out that I can not change the resistor value that sets the switching frequency. Does anyone know if this can be changed manually? TI's default is 300kHz, but I'd like to run much higher to eliminate the need for a bigger external inductor and cap.
Since I couldn't change the frequency in the SwitcherPro software, I figured I'd tackle the design equations manually only to find that TI didn't define all the equation variables in their datasheet...
Any help would be great.
Thanks, Alan
