We use the LM3409 LED driver in EN pin PWM dimming for 4 LEDs. On EN pin is a PWM signal 0...10 kHz. In the range of 0...80Hz switched LM3409 on after a delay, so after turn on need driver longer time to return.
Turns EN pin only OUTPUT FET on and off, or even internally others logic?
Can LM3409 LED driver wired so that this process in the low frequency range does not happen( no external parallel FET dimming)?
Best Regards
