I’m trying to put the TLC59108 LED driver into a new design . I noticed a problem in the datasheet on Figure 12. Iout target Vs. Rext.
That graph does not match the example calculations. If you look in the area of 720 ohms, the example is 26mA while the graph shows ~60mA.
Between the graph and the equation, which is more reliable?
