Looking into LP3972 datasheet, I could not find any timing specification about nRSTI signal.
Is there no timing requirement for nRSTI ? For ex., no spec on reset pulse width ?
Thank you in advance for your help.
Rak
Rak
The circuit between nRSTI and nRSTO is combinatorial logic (no edge trigger element). Since it's not spec'ed, we had not
characterized its delay time over temp and supply. However, for the several gates involved,
I expect it is in the tens of ns range depending on the loading of the I/O pins.
Hope this clarify or answer the concerns of customer.
