LM5025 / LM5025A / LM5025B / LM5025C / CS2 PIN
Other Parts Discussed in Thread: LM5025
Could you please provide Explanation on How the CS2 pin of the LM5025(A/B/C) works?
There is a difference in the data sheet between the A verion and the B version for example.
Could you please explain how this difference effect operation? What are the design consideration in picking the A version versus the B version?
How Do you recommend to Connect the CS2 (Is CS2 a peak detector current pin?).  There are different uses for this pin in the data sheet and in the eval board How is the best way to use this pin?
Why does the voltage from the feedback connected to the CS2?.What is the most recommended way to connect CS2?
Ran
