Other Parts Discussed in Thread: TPS63020, TPS63020EVM-487, TAS5615
I'm working with TPS63020EVM-487. I have modified this PCB to my application, changing FB resistors to have 3,6V output voltage and inductor to make higher current output (1,5uH in EVM to 1uH). The voltage and current output with hardware changes are good for my application. But I have a problem in Shutdown current, in TPS63020 datasheet said that it is lower than 1uA with Ven=0 and in this case, I have had a measurement greater than 200uA. You may said me why have I had this measurement and what is the solution to make it lower?
