Search for battery management
Other Parts Discussed in Thread: BQ78PL114, BQ24610, BQ34Z100
I am looking for a gauge system for Li-Po battery (6S).
I have current pic to 100Ah <30 seconds and an average load of 40Ah. I saw the component bq34z100 but I think it does not comply with the rules of the Smart Battery Data (SBD - SBS) but I need absolutely data stored as the smart battery. the BQ78PL114 chip is exactly what I need but is not recommended for new uses ... must communicate in I2C. I use the charger BQ24610 I search security modules and balancing cells as well.
thanks
  • did you find the answer to this
    I am also looking for a 6s 13.6Ah LiPo Battery Management System and want a Active Balancing, Protection, Consumption monitoring and a separate path for charger(separate IC) and then send data to a CAN node
    I will be great if you can suggest the required products for the above mentioned tasks.
