when the CLA into open loop, the CLA return back to closed loop, result to the output voltage have overshoot!
i try to clamp Filter_Yn_High and KI_High, do not have any effect!
this question how to solution?
Hi You,
You mean when you try to close the loop, there's overshoot on the Vout?
The filter should be pre-setted before you close the loop.
If you have UCD3138 EVM firmware, you can search for function preset_filter0() or preset_filter1() and see what's in there.
Fan
