LM20136 Load Regulation
Guru 20090 points
Other Parts Discussed in Thread: LM20136
I would like to know about the Load Regulation of LM20136.
(1) Condition of Electrical Characteristics of Load Regulation
There are the Figure and the Electrical Characteristics of Load regulation at the datasheet of LM20136.
For Figure (DS 6P.),  there are the conditions of the L , R, Fsw and C.
But, for Electrical Characteristics there are not these conditions. Voltage and temperature condition only.
Please let me know the L, R, Fsw, C conditions of  Electrical Characteristics of Load Regulation.
(2) Cause of the Load Regulation
Please let me know  what parameters was affect Load Regulation.
Refference Voltage ? Gain of Amp ? line of feed back loop ?
Why voltage was changed when changing output current by that parameters?
Ryuji Asaka
  • simply, the current is sensed interanlly...
    the sense R increases with temperature and temperature increases with IOUT, so...
    this "drift" has been characterized and shown in the device datasheet...
    V.
  • PS: if you see, the VOUT drift Vs IOUT follows (same shape) the FB voltage drift Vs temperature,
    both the chart on page 6...
    V.
  • Hi Ryuji,
    1.) The load regulation in the EC table is probably based on the same circuit used to take the typical characteristic curves.
    2.)  The DC load regulation is dictated largely by the open loop gain of the control loop.  The larger the open loop gain, the less the closed loop output resistance will be and therefore the better the load regulation (Zout ≈ Zopen_loop/(1+Open Loop gain).  Load regulation can also be largely dictated by how VOUT is being sensed by the feedback loop.  Incorrect sensing can cause the load regulation to either increase or decrease with load.
    -Dan
  • Hello Vincenzo, Dan,
    Thank you very much.
    I understand that Load regulation is dicated some parameter's.
    And Open loop gain is main cause of Load regulation.
    Ryuji Asaka
