Dear all
One of our batteries controlled by the bq have had two failures both with the PF status VSHUT and AFE_C.(both at the same time). Resetting the PF status everything seems to work OK. Is this type of failure experienced when the bq20z75 is used in an environment with noise ?" The AFE Fail Limit is set to 10. - I do not know whether this setting has any influence on this failure type. We have a rather complex loading (pulsed load with ripple currents) .
I would appreciate any comments because I regards the PF failure as "uncomfortable"
Best regards
Kjell Ramberg
