The datasheet indicates there is a A version of the tps3828-33, however I don't see it as orderable.
Will this release in the future?
Thank you, Keith
Thank you, Keith
Hi Keith,
I will check with the product line; however, I don't believe we are planning to make the 'A' version of the TPS3828. However, we can certainly look into it if the business opportunity is there.
We will be releasing the TPS3823-A (like the TPS3828 except it has a push-pull output stage) and we are currently sampling to customers. I will have to get back to you on a projected RTM.
Darwin
