CEDV calculation problem
hi everyone ,i download a mathcad project  named CEDV6_16_init_2000.mcd on how to calculate CEDV parameters.
in the first page there is a sentence "A03:=READPRN("PN30C200")" ,but where is the file "PN30C200" ? mathcad cannt find this file.
  • Adrian,
    That is an optional file that you can load, if reserve capacity is required for your application. You can ignore it, if you do not require reserve capacity. Otherwise, you can assign a log file for the program to extract data.We find that it is usually ignored.
    Tom
  • thank you ThomasCosby ,
    I'v installed bq2084 softwares and EV2300 tools byside,can i generater the right log file using this tool? and what is the kind  of the extract data format? by the way ,can i download an example extract data on your website?
    Adrian
  • Adrian,
    You can log the proper data using the bqSW. You need Time, Cell Temperature, Cell Voltage and Current. There are some example data files in the data that was downloaded with the MathCad file.They are .dat files that can be opened with Notepad.
    Tom
