Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
LP3972 with PXA270
Other Parts Discussed in Thread: LP3972
My customer would like to know how LP3972 can be connected to Marvell's PXA270.
Do you have example connection diagram of "PXA270 and LP3972" ?
{expecially, he wants to know... 'where to connect nVDD_FAULT of PXA270' and 'how to control 3 VDDs (Core, PLL and SRAM) by PWR_EN (BUCK1, LDO5 and... ???)'}
Thank you in advance for your help.
Rak
    • Subject:     LP3972 PMU interfaces with PXA270 Apps Processor:                                    From: Kern Wong
    •        Apps Engn, TI SVA
    •        Nov. 9, 2012
    Rak,
    Please communicate to your customer to review Marvell literatures online such as listed-
    http://www.marvell.com/application-processors/pxa-family/assets/pxa_27x_emts.pdf
    http://www.marvell.com/application-processors/pxa-family/assets/pxa_27x_design_guide.pdf
    http://www.marvell.com/application-processors/pxa-family/assets/pxa_27x_dev_man.pdf
    Unlike Intel it seems Marvell has in some cases not provide the qualified vendor part information in references I located, as the LP3972 is a qualified part working with the PXA27X processor and SS equivalents.   I am including herein some drawing to answer your questions on which regulator is known to be used on what block and the connection of the nBATT_FAULT line.  Please consult Marvell for up-to-date information and advice.
    * Diagram below depicts regulators in the PMU typical interface to various block in the PXA27X processor: (see image attached)
    Table 8 shows some general interface info between the PMUIC and the processor:  (see image attachment)
    Figure 14 show a generic connection of the nBATT_FAULT connection between PMUIC and Processor:  (see image attachment)
    Figure 5  is another generic block diagrm showing nBATT_FAULT connection between the devices:  (see image attachment)
