When I first power up a new part the FCC is at 6 mah. What is the easiest way to set that to what I want. Since its a new battery it seems I would want the FCC to be the rated capacity.
Hi Dennis,
You need to characterize your battery and create a golden dataflash file that matches your battery and your system requirements. This will then need to be programmed into the fuel gauge. The procedure is outlined in this app note:
http://www.ti.com/lit/an/slua504a/slua504a.pdf
