I've designed a board using the AM3359 MCU that is powered with a TPS65910AA1 PMU, (where due to availability issues we used an XAM3359 part).
In designing the board I refered to the TI TPS65910A User's Guide For AM335x Processors (SWCU093, August 2011) which recommended that the PMU's VRTC output supply be used to power the MCU's VDDS_RTC input supply.
We had three boards made up, one of which was working fine & has subsequently failed (& we haven't quite got to the bottom of why). In investigating this failure, I noticed that there is an up-issue to the User's Guide (SWCU093, version B, September 2012) which recommends that the VRTC supply from the PMU is not connected to the VDDS_RTC input supply to the MCU, in contradiction to the August 2011 version of the User's Guide.
Looking on this forum & in the User's Guide, I've not been able to understand why this change has been made.
More importantly, we are about to make up some more boards (this time using "real" AM3559 devices) whose VDDS_RTC inputs will also be wired into the PMU's VRTC output supply.
Can you please advise, why has this change of VRTC supply between the PMU <-> MCU been made & can devices fail as a result?
Will the MCU/PMU still operate correctly if their VRTCs are wired up as per the August 2011 version of the user guide?
Regards & thanks,
Paul.
Dreampact Limited.
