Does LMR70503 have OVP function?
Other Parts Discussed in Thread: LMR70503
Dear Team:
  My customer Foxconn want to know that does LMR70503 have OVP function? Thank you!
Randy Wang
  • Hi Randy,
    The LMR70503 is an asynchronous inverting buck-boost converter. It does NOT have OVP function such as turning on LS fet to drain the charges etc.
    The only OV condition the LMR70503 will see in normal operation is at no load. Since the LMR70503 has minimum switching frequency and minimum HS ON time, Vout will be charged higher than regulation at no load condition. An internal dummy load is designed to help drain the charges on Cout and to keep Vout in regulation.
    If the OV condition is caused by external current source charging Cout, the LMR70503 will operation at min switching frequency with min HS ON time. The internal dummy load (~7mA) will also turn on to help.
    Let me know if you have further questions.
    Yang Zhang - SVA Simple Switcher
  • Hi Yang,
      Thanks for replying me! Another question: dose LMR70503TM have pre-bias function? Thank you!
    Randy Wang
  • The LMR70503 supports pre-bias start up.
    Yang
