TPS61170 inquiry for 48V Phantom Power Application
Other Parts Discussed in Thread: TPS61170
Hello, all.
Now we are designing portable handy recorder application with TPS61170 for supplying 48V Phantom Power.
The datasheet shows one example to realize 48V Phantom Power supplied by this device.
  • Hello, all.
    Sorry but the remained message was deleted.
    We would like to use this device under the following conditions.
    Vin: 3.6 to 6V
    Vout: 48V
    Iout: 42mA
    Please let me clarify whether we could realize this configuration with TPS61170.
    If possible, please let me clarify which components on the Figure should be changed.
    Thank you for your information.
  • That circuit should be fine as is for your needs.  With your reduced output current needs, you can operate down to lower input voltages.
    Be sure to build and test it before you go to production.
