AN-2178 LM5118 Four Switch Conversion application question
Other Parts Discussed in Thread: LM5118, LM5113, TPS2813
Dear Sir
Good days,
May we check LM5118 Four Switch Conversion application, may we remove LM5113 date driver for cost saving?
                                                    Best regards
        Bogey
  • Hi
    You can remove LM5113. But, in any cases, you need gate drivers.
    Eric
  • Dear Eric
    Good days,
    Many thnaks for your reply~
    Is here having any impact  when we remove LM5113 and just use TPS2813 inLM5118 Four Switch Conversion application?
        Bogey
  • Hi
    TPS2813 is a dual low-side NMOS driver which cannot be used for half bridge structure. You need  a half-bridge driver like as LM5113.
    Eric
  • I have a question about the LM5113 (alternative parts capable of much higher frequency), but can't post details publicly. How can I get old fashioned phone support?  This e2e thing made me choose other manufacturers in the past. I'm surprised TI still shields itself from customers. Look at Linear - best support in the industry.
  • Dear Sir
    Thanks for your reply~
        Bogey
  • Typically you would contact your local FAE for direct support. Alternately, you can contact me directly at j-tucker(at)ti.com. I can forward your inquiry as I do not directly support any LMxxxx devices.
