Currently using a 4.5 Ah sealed Lead acid battery with a simple zener charge circuit.
Need relatively simple conditioning battery charge solution so I can leave the tester plugged in 24/7.
Hoping for a single IC solution.
I will be using a 24 VAC transformer with a bridge rectifier to supply the charge circuit because I need a dual test supply capability of 12VDC and 24 VAC.
I am new to battery charging
Am looking at the UC2906 and UC3906 ICs.
Are these suitable for charger 12 VDC lead acid batteries?
Thank you in advance for reading and any help you might "supply" my supply. :)
