EVSW - what is the correct version for autodetecting bq20z45_R1?
Other Parts Discussed in Thread: BQ20Z45, BQEVSW
Dear all,
I am currently using EVSW 09.79 that works fine on a Windows Vista operating system and there is no problem autodetecting bq20z75 V 1.60 or bq20z75 V 1.80.
I want to evaluate the bq20z45_R1 sinse I have been recommend to test this version in our application, but I have problem autodetecting the board.
I have tested EVSV 09.64 that autodetects bq20z45_R1 but that version will not autodetect bq20z75. Hopefully there exists a version for Windows Vista that works for both types.
Any info will be very much appreciated
Best regards
Kjell
  • Kjell,
    It should still auto-detect your bq20z45. You should try rerunning the bqEVSW setup file for the bq20z75-R1 to make sure that all of the files have been updated.
    Tom
  • Tom,
    That was a good idea.
    Normally I do not like to install on sw "on top of the other" - but this time it worked fine. Having a 09.79 installed and then running the sluc157 (setup for 09.64) did the job. Now I have autodetect of both bq20z45, bq20z75 V 1.60 and V1.81.
    If I tried installing the 09.64 first and 09.79 "on top" then it would not work at all.
    Problem solved, thanks Tom for your support.
    Best regards
    Kjell
    Since I had installed 09.64 (to autodetect the bq20z45)
