We know we can use Inhibit Pin to enable/disable POLA output. I want to know if we can also use Track pin to turn on/off the module:
1. Pull Inhibit Pin Low(Use NMOS) => disable output;
2. Inhibit Pin is open, pull Track Pin low then disable output;
3. Inhibit Pin is open, pull Track Pin High (e.g, 12V), then enable output;
Thanks.
