PWRON in slave mode on TPS65930.
Other Parts Discussed in Thread: TPS65930, DM3730
Hi all,
I have a processor module with DM3730 powered by TPS65930.
I have some issues about PWRON pin. I know that TPS65930 is configured as master mode. For my application, I wants DM3730 boot, when pwron button is pressed, instead detection a valid Vbat.
My question is:
Is it possible on master mode?
Adriano
  • Adriane,
    this is not possible on the first supply insertion but this is possible on all folowing power insertion if you have a backup battery present.
    After first boot, clear STARTON_VBAT bit in CFG_P1_TRANSITION, CFG_P2_TRANSITION, CFG_P3_TRANSITION registers.
    configuration will be saved thanks to backup battery and PMIC will not start on next main power insertion
    regards,Alexis
