I use BQ24070 for 18650 Li-on battery charge, I set charge current 600mA, Iset2=high, Mode=high,
as datasheet mentioned, the Stat1 will go high and Stat2 will go low, but when I test BQ24070 with charge current <60mA,
the Stat2 remain high, not go low . so the silicon result is different from datasheet.
which part is correct? does charger still on after charge complete?
thanks
