This might be a lot to ask, but has anyone done a single port PSE design? We only plan on using 4 lines out of the 8. We only need about 10W out. Our voltage input is 30V-60V, which I realize is higher than the 57V max. There might be a simple LDO we could use on the front end to take care of that.
I'm curious if the TPS23841 would be appropriate to use for this design, and if someone has done this, we are curious how much board space it take up.
Thanks!
