Our customer are evaluating UCC28950 on their preproduction board and then they found abnormal operation as attached waveform. Following is its explanation.
- One side operate with max duty and the other side with 0% duty as attached waveform (Look like pulse skipping)
- This condition happens at heavy load
- The frequency of this operation about one time per second but suddenly and irregularly (Depend on load)
- It was not confirmed at all samples but confirmed about 30pcs per 100pcs.
- This abnormal condition is fixed by changing RTMIN register from 47kohm to 12kohm (Schematic stated after changing)
I would like to have your advice for;
- Estimated root cause for this abnormal operation
- The reason why changing RTMIN register fix this abnormal operation
Sonoki / Japan Disty
