I need the dimension of power pad in 16-lead TSSOP pakage. The parts full part number is LM3421MHX. I already tried in SLMA002G.pdf. It mentioned the power pad size as 5mmX3.4mm. The whole IC dimension for 16-lead TSSOP is 6.4mmX4.3 only. The power pad dimension mentioned in SLMA002G.pdf 5mmX3.4mm, which I feel incorrect and the dimension does not matches with illustrative figure mentioned in LM3421 datasheet. Please let me know the correct dimension of power pad for 16-lead TSSOP for part number LM3421MHX.
Bakyaraj T
