TPS74401 pre-bias capable?
Hello:  my customer has a question:
"When enable is pulled low on TPS74401KTWT, is the output tri-stated?  I have an application where I may use the output of this LDO or the output of another power supply and want to make sure that there isn’t a problem with this LDO if I have it disabled and apply voltage to its output."
regards, G Biner
