dissipative battery management system?
In the charging / discharging process of Lithium Iron Phosphate cell, (nominal voltage about 3.33 vdc of a A123 20 ah cell) .  Is there a means through  through Texas Instruments electronics to track voltage of the individual parallel packs and shunt amperage through the charge discharge process  on the parallel cells.
In other words,   proportionally applying resistant  to the cells with the least capacity based on  a voltage signal of the the parallel pack with the most capacity,
therefore all parallel packs in series always have the same resistance?
Thank you,
Mark Yormark
