Now our customer evaluating TPS62110 and then we received questions about sync pin as below. Can you please confirm them?
1, Can customer float sync pin? Which mode does TPS62110 operate with PWM forced or PWM/PFM if floating will be acceptable ?
2, Can customer tied sync pin through pull-down resistor ? They plan to switch sync pin VIN to GND through pull-down resistor dynamically。
Sonoki / Japan Disty
