How many devices (AMPs) can a TPS7A4901 support?
Hi Amy,
This device is rated for 0.150A. However, it depends on the input and output voltage operating conditions so as to not exceed the maximum junction temperature and reach thermal shutdown. What is the operating condition of your application?
Darwin
Hi Amy,
TPS7A4901 and TPS7A3001 are low noise, high voltage, low power devices, and will fit well for your application. Since the op amps operate at low currents, you will not have to worry about thermals.
Darwin
