we want to try out your wireless power solution and for that case I need a wireless power receiver that is able to charge a LiPo-battery with integrated battery management. That means we need to power our portable device from that LiPo-battery when the device is in use but as soon as it's back in its loading station the battery shall be charged.
I read your application report slua651, "bq5105x Direct Charging Efficiency Comparison", which says that concerning efficiency one should use an integrated charging solution instead of using a discrete solution. Surely I can use the bq5105x as a "standalone" battery charger - but I do need battery management to switch from power source to battery.
Can you help me please?
Kind regards,
Stephan
