TPS63060, failing when hooked up to +12V gel cell battery
Other Parts Discussed in Thread: TPS63060
I have a problem with TPS63060. I have configured it for a 3.6V output. When it is powered by a power supply, it works perfectly. However if I use a gel cell battery the unit the unit is permanently is damaged.
Is there a relation between in-rush current from the gel cell battery and this device?
