I have previously used the LM317 TO-92 Plastic package and am pleased with the results. I would however prefer to use a surface mount equivalent to save space on my final PCB. As far as I can see, the smallest package available is the SOT-223 (EMP). This part has 2 Vout pins (1 sandwiched between Vin and ADJ, and a second longer tab on the other edge). I wanted to double check: is there a difference between the two pins, and which one should I use?
Many thanks,
Hind
