Other Parts Discussed in Thread: TLC5951
Hello I'm new using the TLC5951. I'm designing and building a project with the TLC5951 to drive multiple RGB led's. The chip I got is DAP packege, for the purpose of prototyping is there any adapter to get it to go to a breadboard? If so do you sell the adapters or the IC's already mounted on PCB? I'm going to be using 8 TLC5951 to drive around 60 RGB LED's. If it is not available through TI can you sugest a wat to use the DAP in a breadboard. Thank You as you see I'm new with the electronics projects.
Anything would be appreciated.
Hector
