TPS2540 does not use Vbus Power sw(IN & OUT pin is Open).
Can TPS2543 use only " USB charging port identification circuit "?
Vbus Power sw uses the IC which is different from TPS2540.
I am terribly sorry.
A question about TPS2540.
(TPS2543 is typo.)
[Question]
Can TPS2540 use only " USB charging port identification circuit "?
Please check attached file.
What's your application? There are SDP, CDP, DCP_Auto mode, whic mode you will use? In additon, why you want another power switch since TPS254x has integrated power siwtch and current limit is adjustable, or the Rds,on is too large for your application?
Hi,Milo
Thank you for your prompt reply.
I’m sorry. The specifications of my customer were changed.
My customer fixes CDP mode.
There is not a mode change.
Is the discharege function unnecessary?
(Please confirm an attached file.)
Please let me ask one more question.
It is the following condition that power switch of TPS2540 is changed (OFF to ON).
Do other conditions exist?
• Any transition to and from CDP
• Any transition to and from SDP
