Dear Sir
I am Working on LED Driver TPS61165 through this i want to drive a single LED whose Voltage is 3.3 volt and 1 watt.Can i drive the same.Or suggest the alternative to driver a single led
Tanvi Verma
Be sure to always begin the title of your post with the part number. We support many LED drivers in the LED driver forum, so LED driver by itself is rather uninformative.
I'm not sure that the TPS61165 is the best option for driving a single LED. What is your input voltage range?
Dear Mam
The input voltage is 1s li-ion battery i.e(3.3v to 4.25v ).And can i use LM-4040 i.e Shunt Voltage Reference as a PWM generator
Tanvi Verma
I would recommend a TPS630xx buck boost converter, such as TPS63000. There is an LED driving app note on the product page.
You need to begin a new post in the appropriate forum for support on the LM device.
