powering a USB device
Other Parts Discussed in Thread: TPS61170, TPS61256
We need a 3.3V to 5V, 500mA charge pump IC/boost to use with the SMSC USB3320 USB Transceiver.  It must be compatible with a 3.3V logic enable and be as simple as possible.   It will power a slave USB device up to 500mA through a USBA connector. Do you have any recommendations that you can offer?
Cheers
Calum
