BQ51013B thermal pad connect to ground
Other Parts Discussed in Thread: BQ51013B
I am interested in using BQ51013B in my project.
There is an exposed thermal pad under this chip for heat dissippation.
Due to the space constrain on PCB board, can I connect the thermal pad to ground ?
so that I can save space and also strenghten the grounding and improve heat dissipation as well.
The datasheet didn't mentioned that the thermal pad can be connected to ground.
Hope to hear from you soon.
Thank you.
