About TPS65023 Loop Gain ,Phase marjin
Other Parts Discussed in Thread: TPS65023
Hi
Could you tell me how to measure Loop and gain margin at TPS65023?
My customer no use FB resistance. Use default output voltage.
If can measure, please let me know pace to measure
Best Regards
    You can break the feedback loop at the VDCDCx pin. If you break the your loop between the Vout and VDCDCx pin to inject your noise here, the response can be taken accurately. It is also suggested that you do a transient response test on the output too.
    However, you change to use the DEFDCDC pin as the resistor divider feedback network that it can be, you must break the loop between the top resistor and Vout. Then, leave VDCDCx shorted to the output.
  • Michael Green
    Thank you for your  answer!
    Best regards
    masa0301
