I'm going to use the BQ51050B Wireless Power Receiver and Battery Charger in my next design, and i've got some questions regarding the receiver coil. On the transmitter side i would use the BQ500211 Transmitter manager.
I would like to use the following coil on the receiver side: Würth 760308201
Is it possible to use this coil with this receiver?
Further the Data sheet of this coil mentions a quality factor of 50.
The equation 6 of the BQ51050B datasheet says that the quality factor has to be greater than 77.
Calculating with this equatation i get a quality factor for the same coil that is greater than 77.
Is this quality factor compareable or does it has to be calculated with the equation?
Best regards
