Measure present current with bq34z110
I am able to sense the present voltage and state of charge of a lead acid battery using the BQ34Z110EVM. The datasheet only shows the AverageCurrent() command to sense current. The evaluation software however also has a field that shows the present current through the sense resistor.
Is there a straight forward way to sense the present current flow using an I2C interface?
  • Anmol,
    the instantaneous current can be read with a Control subcommand. Please see page 10 of the datasheet. You can refer to this e2e forun ink for examples of reading a Control subcommand.
    http://e2e.ti.com/support/power_management/battery_management/f/180/p/213060/820268.aspx#820268
    Tom
