Hi
TPS40400 have a crrent sense using sense resistor and inductor resistor,
But my customer want to no use ISNS pin.
Can I possible to no use ISNS pin?
Best Regards
Hi
Best Regards
Hi Masa,
You can leave ISNS pins not used. The IOUT_OC_FAULT_RESPONSE needs to be set to continue operation without interruption.
Then basically, the device will lose the current monitoring and overcurrent protection. It is not recommended.
Na
